Jaké jsou výhody a nevýhody digitálních mixpultů?
Ota
Příspěvek od Ota »
jans: :smt023 :D
No a jak v praxi? Osvědčilo se?
Fyla
Příspěvek od Fyla »
To by me taky zajimalo, jaxte dopadli :-D
Ovladani pultu telefonem a podobne si dokazu v praxi predstavit treba na celkove nastaveni systemu - muzes si behat po sale a upravovat nastaveni procesoru, eq...
Ale nic vic :)
jans
Příspěvek od jans »
hlavny zvukar si normalne nezavisle na podiakovy robil zvuk von a podiak nezavisle na hlavnom zvukarovi robil zvuk na podiu.. je to parada nepotrebujes dalsi monitorovy pult, a kedze to bol tablet s dotykovou obrazovou islo to celkom pohodlne
neviem ci ste dobre pochopili kedze sa ja neviem asi poriadne vykoktat ale bola to parada a hlavne skusky isli rychlejsie
Fyla
Příspěvek od Fyla »
Nedokazu si toto ovladani moc dobre predstavit. Co delal pan zvukar, kdyz mu zacali hruzostrasne hvizdat housle na kanale 43 v osme ceste?
jans
Příspěvek od jans »
hovorim odposluchy riesil podiak cez tablet a vsetky zasahy z tabletu sa prenasali cez siet do mixu a ked bolo treba daco resit pouzili sa vysielacky alebo pisanie odkazov do notepadu :-)
z mackie.com
TT CONTROL SOFTWARE
The TT24 ships with Mackie's powerful TT Control software, which can be used to control and monitor the console using a laptop or desktop PC. Once connected via a single USB cable, TT Control software provides a large, full-color view of the TT24’s touchscreen. In addition to providing a larger view, the TT Control software’s interface was designed with daylight usage in mind (i.e. we used black lines on white backgrounds or bright yellow text on black backgrounds). In default setting, the TT24's LCD screen is mirrored in the in the software, making it easy to keep your hands on the control surface with your eyes on the computer monitor. But the software can also be set up to operate independently of the console if a second engineer is working. Additionally, TT Control allows for convenient file saving and firmware upgrades via PC.
Fyla
Příspěvek od Fyla »
hovorim, ze kdyby to bylo tak uzasne jednoduche a prakticke, zvucilo by se z pocitace mysi davno a vsude, bo je to hrozne levny - a mackie k tomu nepotrebujes... :D
xb
Příspěvek od xb »
ja pouzivam tt24 taky a to co tady popisuje jans je mozne spachat, ale ty hruzostrasny housle 43 v 8my ceste bych s tim resit asi nechtel ;)
ja pouzivam notebook ve spojeni s tim pultem spis jako meterbridge, na ovladani to moc pohodlny neni a radsi si sahnu na zelezo nez abych klikal. myslim ale, ze je to hlavne otazka zvyku.
jans> mate v tom pultu nainstalovane nejake rozsirujici karty (ufx, unet) ?
Příspěvek od safa »
Fyla píše:hovorim, ze kdyby to bylo tak uzasne jednoduche a prakticke, zvucilo by se z pocitace mysi davno a vsude, bo je to hrozne levny - a mackie k tomu nepotrebujes... :D
... mmno taky jsem o takovejch pokusech slysel, dokonce jsem na to i videl softik. Zkusil jsem si to vloni na vystave ... jen tak pro legraci abych si zkusil ze to jde. Zvucil jsem pres kartu EMU 1616M (ma vychytanou aplikaci Patchmix ktera to umoznuje vcetne EQ a efektu) triclenou kapelku a docela se to dalo (hrali tri skladby). Samozrejme ta aplikace na tohle neni delana takze to bylo trochu vick klikani nez bych si predstavoval ... ale byl to uspesnej pokus. Navic jsem to rovnou v tom samym pocitaci do Samplitude nahraval ;-)
Fyla
Příspěvek od Fyla »
safa píše:
A prece se toci!!! :-D
jans
Příspěvek od jans »
hlavny zvukar robi normalne na pulte, notas sluzi iba na prepojenie pre podiaka
pripojena tam je iba procesorova karta (typ neviem) aby mix utiahol 40 kanalov pretoze pripajame dalse dva onyxy (adat mikrofonove preampy)
Zpět na „Mixážní pulty“
